  • 7 Replies
  • 410 Views
  • 5 In Conversation
CARLIER
Bonjour, suis  la recherche d'un chargeur pour batterie A-1C utilisée pour PRO 2, avec 4 pins de charge donc équilibrage de la charge.
Merci
7 REPLIES 7
BrookeN
The Pro 2 cameras are EOL and are no longer sold on Arlo websites nor are their accessories. You would need to look online for the batteries and see if you can find someone selling them.
I think you want a charger, not replacement batteries.
Arlo doesn't sell those either, but you there are some third-party options for stand-alone charging stations.  AFAIK, only two of the pins on the battery are used for charging.
If you want to charge the batteries in the camera, you should look for an external usb charger that supports Qualcomm. Quick Charge.
CARLIER
J'ai trouvé un double chargeur sur Ebay (https://www.ebay.fr/str/igreencell2019) qui fonctionne correctement, mais les 2 batteries fournies ne débitent que 500 mA/h alors qu'il est inscrit 2500 mA/h! Ceux-ci m'ont remboursé l'achat.
J'ai un banc de test pour les batteries Li-ion. J'avais confiance aux batteries ARLO
Je vous remercie de vos réponses.
Arlo certified the Tenergy batteries and charger for use in the original wireless cameras that use 4 CR123 batteries. They are the onl rechargeables Arlo ever certified. @TomMac and I went through a whole bunch of different batteries with Arlo before Tenergy was approved. Non-certified rechargeables did everything from claiming as much as 2500mAh to burning up cameras due to lack of protective circuitry (and probably poor manufacturing). I assume you could search the archives here back in 2015-2017 to find the threads about all this. I still have a set in use.
Here's the link to the current product:
https://power.tenergy.com/certified-rechargeable-batteries-arlo-8-pack-charger-premium?searchid=2856...
CARLIER
Thank you but not compatible with my Arlo PRO2 cameras.
Not tested at this Thime, mais j'ai commandé ici: https://www.batteries-plus.fr/batterie-a1-for-arlo-pro-pro-2-vmc4030-vms4230-vma4400-cameracompatibl...
Sorry, I misunderstood the camera model.
Edinburgh_lad1
You can also use an ordinary phone charger like Motorola turbo charger to charge Pro 2 batteries. It's cheaper to get. The model number is Motorola SC53 (it supports QC3.0), so any Qualcomm supported charger will do effectively. Any because this charger has a usb port, you just need to use a microUSB cable with it and usb-c for your phone, if you have an android phone. Think about the environment and how we can re-purpose existing equipment without buying new. Also, when charging, I'd probably trust a better known brand - like Arlo if you have the original charger, or Motorola - than something from AliExpress or wherever people buy from. Just look at the label of your existing chargers and if it has QC3.0, then you're good to go ahead.
  • 7 Replies
  • 411 Views
  • 5 In Conversation
