Change notification sound after a specific time?
  • 1 Reply
  • 1286 Views
elasticeye
I want to change my notification sound to a louder sound between 11 pm and 6 am so I can wake up if unwanted guests are lurking around by night.
Is this possible to set automatically?
Thanks!
If not, any reason why it can't be done?
Dannybear
Using the iOS app the feature is missing, it was about early under netgear but was removed from what I recall under arlo.
The android app is similar but some say that they have a workaround.
Just search the arlo website for posts about the feature, plenty of them
  • 1 Reply
  • 1287 Views
