Hi,
What is the capacity for video recording in the cloud for free subscribsion?
If you don’t delete anything what happens, will the oldest video clips be deleted when it’s full or how it’s working?
A couple years back, cloud storage for Basic or Free level was at 10Gb (?).... but then that was removed.
The storage is based on service level days now ( not amount )... so with the free service it's 7 days storage
Very simple, on day 8, day 1 is auto deleted, day 9 follows with day 2 deleted, etc.
You don't have to worry about amount or manually delete, BUT you should d/l anything you think is important and/or use a mem card for the usb backup option
And If I have 24/7 recording, it’s the same 7 days?
24/7 recording ( if you mean the CVR option ) is a paid extra. (diff length time frame )
If you mean powered all the time to record and armed it's the 7 days max
