  • 3938 Views
SC_Kwok
I am using Arlo pro 2 with iOS 13.3, Cannot use the hold and speak function during screen after app updated !
Anyone encountered the same problem, hope Arlo app team fix the issue ASAP
NewfieDrool
Luminary
Luminary
On your iPhone go to settings and scroll down to Arlo and make sure it has permission to use mic.
NewfieDrool
Luminary
Luminary
Just tested on my iPad Pro running the latest iOS and it’s fine. I take it you have rebooted the phone/iPad just in case as IOS13 is not a very stable system at best.
You could also try a fresh install of the app.
Also under settings on your device insure app has access to mic.
SC_Kwok
Reboot but still no luck ! I am using iPhone XS Max with iOS 13.3
NewfieDrool
Luminary
Luminary
  • 3939 Views
