  • 7 Replies
  • 2440 Views
  • 3 Likes
  • 5 In Conversation
TonyMika
Hi
I can’t seem to find where/how to rectrieve my cloud based recording back-ups and need to access it ASAP as I have the limited 7 day loop
7 REPLIES 7
brh
@TonyMika
Are they not showing up in your library?
Brian
HermanLily
No Brian, there is NO library
App or browser? Have you tried both as well as reinstalling the app?
brh
@HermanLily
In your app you should have 4 icons:
1) Devices
2) Library
3) Mode
4) Settings
What are you seeing in your app and have you logged into your account on a pc?
What smartphone and app are you using?
Brian
HermanLily
I have all of those within my app. I am on a GS8....once any recent events have been viewed, there is no way to go into the library of each device. I have not logged in on a PC as I have never needed to.
HermanLily
App 🤔 since the update of the 20th or 21st, something was screwed up....terribly
JessicaP
Hey @HermanLily,
I would suggest try checking on your PC that you are able to access the recordings so we can make sure your recordings are still there.
  • 7 Replies
  • 2441 Views
  • 3 Likes
  • 5 In Conversation
