I am trying to grant access to my wife. Below are the steps I am taking.
- I enter her name, email and check off one of the camers. I then hit send.
- She recieves the invitation and clicks it.
- She clicks the "create account" button to setup her account
- After entering her email, the site takes her to a login page. She enters a password but nothing happen. Upon clicking login a popup appears for a second that says "please wait", then disappears. Clicking the login button does the same each time.
- After hitting the forgotten password button. The system says it is sending out an email for resetting the password. This email never comes through. I have checked spam as well.
Any ideas on how to fix this?
For those that might have this issue in the future. Jessica opened a case for me. Arlo support had to reset my wife's password. Doing that enabled me to get the email and change the password sucessfully.
Hey kennyr35,
Does your wife already have an existing Arlo account or did she create a new one after clicking on the "create account"?
It looks like there is some sort of bug with her account.
- When she click's the link in the email and clicks "create account".
- She enters her email and hits "next".
- The system takes her to a login page instead of the page to setup the account.
When you say she clicks on "Create Account," is this after clicking on the "Create my Own Arlo Account" or "arlo.netgear.com" correct?
Try re-sending the grant access invite again and try using a different browser or on incognito mode to see if that helps.
Jessie,
- The invite comes to her inbox and she clicks it.
- The link takes her to a site to login.
- She clicks the green button at the bottom that says "Create Account"
- She inputs her email address and clicks "next"
- The next screen shows a login page and not the "create account page" where you enter your name, re enter your email and password.
I tried what you mentioned. Same result.
Thanks for the detailed information. When you say "you enter your name, re-enter your email and password", could you verify which screen you're seeing (see screenshot below)?
I am seeing the 2nd one shown (the login/password screen). The first screenshot should be showing up, but it doesnt.
Thanks again for answering my question. There may be a chance your wife already has an account. Let me reach out to you via private message to gather more information from you.
