  • 1368 Views
swoop01
Bonjour,
Pouvez vous me dire si je peut rajouter une camera Pro 2 sur une station equipé de deux simple camera (non pro)? ex ce que le melanfe de deux modele different ne pose pas de probleme?
Bav,
brh
@swoop01,
The Arlo HD, (original), Pro and Pro2 will work with any base station model, so yes, you can mix them on the same base. The VMB4000 base would be preferable. Only the Ultra cameras will not work with earlier base stations.
Brian
swoop01
Hi,
Can you tell me if its possible to place a Pro 2 camera, with a installation who already has two simple camera's? If i the base station who can receive Pro2 camera's. The VMB4000 workstation, so this woud be not a problem.
But im not sure if you can mix both types off camera's?
brh
@swoop01,
Brian
swoop01
Thanks for the info Brian!
  • 1369 Views
