I read a thread or two which supposedly had a solution but either no solution was actually provided or the menu options did not exist in my interface.
Can the time be increased to at least 30 seconds each time movement is detected?
In the app go to the Mode Icon and click on it.
Select the Armed Mode.
On the Edit Mode page, click on the green pencil beside the camera you wish to increas the record time on.
On the Edit Rule Page. go down to the section where it says Then Do The Following. Click on the green pencil beside Record Video and adjust the slider to the desired time up to 120 seconds.
At the top right of the page click on Save.
Brian
Brian
Thanks,
shortly after posting I found it via the Select the Armed Mode.
