Can't get Arlo app to add iPhone 8 as trusted device. Have PN on.
I can't get the app to add my iphone 8 as a trusted device. After I go through the two factor authentication, it asks if I want to add my phone as a trusted device. If I say yes, it says Turn on Push Notificaitons. I have all notifications turned on. I have turned my phone off and on and it still does the same thing.
Hi JMor,
Just to be sure, are you saying you don't see your iPhone 8 listed as a trusted device under Two-Step Verification setting? If not, then try to uninstall the Arlo app, reboot your iPhone, and re-install the app to see if that helps.
