  • 1 Reply
  • 723 Views
JMor
I can't get the app to add my iphone 8 as a trusted device.  After I go through the two factor authentication, it asks if I want to add my phone as a trusted device.  If I say yes, it says Turn on Push Notificaitons.  I have all notifications turned on.  I have turned my phone off and on and it still does the same thing.
JessicaP
Hi JMor,
Just to be sure, are you saying you don't see your iPhone 8 listed as a trusted device under Two-Step Verification setting? If not, then try to uninstall the Arlo app, reboot your iPhone, and re-install the app to see if that helps.
  • 1 Reply
  • 724 Views
