I am currently in Houston and bought my Arlo at Best Buy there. My Amazon Echo Show I got directly from Amazon.
Hi Steve, Sorry to take so long to answer. No, I am in Barbados but my stepson managed to get everything working.
You should contact Amazon with this problem and if they cannot help you see if you can return the item. I am quite sure it has nothing to do with Arlo. If you Google "Alexa Skills Geographic Restrictions" it will give you some ideas as to what could be causing this.
Brian
Your amazon account / home address isn't in Canada by any chance?
Hi Jevan,
Do you mind sharing how your stepson got around the restrictions. I live in Barbados as well!!
Trying to integrate Samsung Smarthings into Alexa..getting grief!!
Steve
No worries. I got it done. Changed the country under Devices and Contents - Settings in Amazon.
