Can't access Library on 1st of the month
Hello.
On the first of the month, every month, I can not access recordings made during the day. Eventually I can access them, but I haven't noticed at what time I'm able to. Right now at 7pm local time, I still can't see today's recordings.
Screenshot attached.
Using the Android app on a Samsung Galaxy S9 +.
Hey @seoidau,
Have you tried logging through the web and see if you are able to view the recordings through there?
Hi @JessicaP.
As at 7am local time on the 2nd of the month th, videos were still not showing, and the date couldn't be selected – I know I had recordings but no green dots were showing under 1 nor 2.
I force-closed the app and loaded it, and could see the recordings for the 1st and second.
I didn't try trough the web, but this appears to be an Android app bug.
If the issue is still persisting, try to uninstall the app and restart your phone. Then reinstall the app.
I had a similar issue and a force close of the app fixed it.
