Can not connect my camera after removing it from new app
  • 5 Replies
  • 2741 Views
Roy1916
Hello,
I have problem.
Yesterday I accidentally deleted device from app arlo, and when i try add my arlo pro again it can not be added.
Any one can help resolve this problem ?
Camera SN: A0B19378A568A
Wireless camera Arlo Pro 2
5 REPLIES 5
michaelkenward
Sensei Sensei
Sensei
How are you trying to add the camera back?
Sync buttons?
Just another user
Roy1916
Yes! I tried follow the instructions on the app to add camera back to the station, but after the blue LED blink , it nothing happened. The app couldn’t find my camer.
If you can, attempt it on a computer...  https://my.arlo.com
Or just do it without app.... Press the base sync button ( quick press only ) and then the camera sync button.
the slow blue should turn to quick flash if it works.
Roy1916
@TomMac Yes, I tried that as well, but after quick blue flash, I checked the app. There is no camera added.
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 5 Replies
  • 2742 Views
