Can You Add A Arlo Pro 2 To A Regular Arlo Base Station With Three Arlo Cameras?
Can you add a Arlo Pro 2 to a reqular Arlo base station station with three Arlo cameras?
Yes. I have one system set up that way.
The better solution is to get a new system and add your old cameras to a new base, so you can get USB backup storage, much better button and LED placement and the alarm (if that is of any value to you). Or even consider a two base station setup, if possible, to get better coverage around the building.
