Can I used my fixed monitors with Arlo?
Can I used my fixed monitors with this system ?? Using this system on my boat more to see things and monitor areas , more so than a security system Thanks Capt Ted
Doesn't sound like a good fit for Arlo Pro 2. You cannot connect the cameras directly to a monitor. All video data goes to the cloud and back down, so you cannot use it without an Internet connection.
