Can I record to the cloud and local USB simultaneously?
  • 2 Replies
  • 2958 Views
JasonDxxx
brh
The Arlo Pro base station has two USB ports built into it. You can insert a flash drive into each port or just one of the ports and it should record to both the cloud and the flash drive. But to view the videos on the flash drives you must remove the flash drive and insert it into a computer. There is no "Live" viewing of the flash drive.
Brian
steve_t
Master Master
Yes, as long as you have the base station that comes with the Pro or Pro 2. If you have updated to one of these, you might want to change your info at the bottom of your posts 🙂
  • 2 Replies
  • 2959 Views
