Can I get another base station to be used with the 2 extra cameras at another location?
I have 2 extra cameras that came with my 6 camera Arlo Pro 2 package. Can I get another base station ,by itself, to be used with the 2 extra cameras at another location? Thanks
You can use as many bases as you like on any account ( and location )...the limiting factor is the number of cameras.
Basic ( free ) is 5 total ... (exception is if you purchased a 6 pack then it is 6 ( special code/serial # when opening acount ))
So your G2G
