Hello there,
I setup homekit for my arlo pro 2 cameras in the past. Recently the connection to homekit got some issues, so I removed the cameras from homekit and try to add them again. However, I got stuck at the Discovering devices screen. Based on my research in this forum, I'll need a homekit token reset. Can anyone help me do that? Thanks very much!
Thank you
Thank you
Awesome, it works now. Thanks very much!
Pokemyles,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Just wondering if I could get a reset token for Homekit as well please. Having the same issues and seems to be the general solution.
Thanks,
M.
MMoreland,
PokeMyles,
Could you provide more details about what you're experiencing?
