Can I adjust the sensitivity of the Arlo Pro 2 camera?
Can I adjust the sensativity of the camera, my driveway camera faces west and every afternoon when the sun comes over my house and started to cause shadows my camera goes off all the time, several times as the shadows move?
Hi Bucky513,
You can certainly adjust the motion sensitivity for your Arlo camera. You can read here on how to adjust: How do I change the motion sensitivity on my Arlo camera?
You can also use the Motion Detection test if needed: How do I use the motion detection test for my Arlo device?
