Can I adjust any settings to increase the sensitivity of the microphone?
My arlo camera is permanently fixed close to a corner of a 3x3 m room. It is located in an excellent location for capturing images but it hardly records any conversations properly, unless people in the room are shouting. It behaves as an 'almost deaf' camera.
I tried to increase the sensitivity of audio recording but cannot adjust it. I can only adjust the volume of the speaker but not that of the microphone. I do not wish to change the location of the camera. The room is not too big, so it should be recording standard conversations properly. Can I adjust any settings to increase the sensitivity of the microphone?
Not really... it may just be the location isn't receiving much sounds in the corner....
Temp move the camera and test it in a different location to see if the mic functions well
