Can 6 camera Arlo version (VMS4630 or VMS4630P) be supported in Singapore?
The 6 camera sets only work for all 6 cameras in the US and Canada. The best you could do would be to buy and set up the systems in the US, shut them down, transport o Singapore and bring the systems back up. If you ever have to reset the systems you'll lose the 6 camera capability for free.
Dear Jguerdat,
Thank you for your fast respond. That would not work for us, so how about the 5 camera Arlo version (VMS4530 or VMS4530P) support in Singapore? As in Singapore we don't find any distributer selling 5 camera Arlo version, we would like to purchase online, is that possible.
Thank you.
Best regards,
Mike
Dear Sir/Madam,
Can I also check whether if I brought 6 camera version (VMS4630) online, but use (pair) only 5 cameras, is that possible?
Thank you.
Best regards,
Mike
Any of the various Arlo systems will work in any country that allows Internet access to https://arlo.netgear.com. Not all countries do so check first. Then there's the issue of power adapters - while the supplied adpaters will work on 100-240v, the plug configuration for your country would be different from those in the US. You would need to have the proper adapters to plug them in.
The use of a 6 camera set in Singapore will work fine although you would only be able to utilize 5 cameras at a time so don't pair that last camera - use is as a spare.
