Cameras lose sync at night
I have successfully installed my pro2 system. Everything works in daylight. As soon as it gets dark, 3 out of 5 cameras lose sync. Two red LEDs flashing. At daylight they resync. They are AC powered so not a battery issue. One failing camera is 5 feet from its base station with one external stucco wall between camera and base station.
try and swap one of the good cameras with a troubled one... see if the issue follows camera.
It may just be interference... Stucco is poor for wifi signals as it contains wire mesh.
Signal strength is strong in daylight hours. This is 5 feet from the base station + 1 stucco wall. I have swapped cameras before but before i isolated the problem to nighttime. I will try this Monday night.
