Cameras Not Recording & Saving To Library
Two days ago I had recordings in my library. Now, nothing. Any suggestions?
Did you try restarting your base station?
Also, are they old enough that they are no longer displayed due to your plan's number of days of viewing them? The free plan only allows 7 days' worth of viewing. In addition, make sure you don't have a filter set in the library. The funnel icon should be empty, not filled in. If it is, click on it, reset it and save.
