Camera wont stay conntected or charged
I recall reading somewhere that best practice is that you should not let the camera battery fall below 15%.
If it is allowed to die completely in the camera, it may take a number of charging cycles to get the battery to reach full memory capacity, a bit like the memory issues that you get with NiCad batteries.
I feel silly for not thinking of that before. Yes, the camra works good if i switch the battery. You said it takes a few charges to fully charge? Does that mean i can keep charging it and it will eventually get to full charge or do i have to buy a new battery?
Lithium Ion batteries dont like being fully discharged, it may not ever recover from being taken to a fully discharged state. I assume there is enough technology in the camera to shut it off to prevent this from happening. Cycling the battery may fix the issue, but its not likely. Generally the battery will lose the ability to provide good current draw, it may fully charge, but will not provide longevity during discharge.
Well thank you so much for your help. It seems they sould be paying you and some of the other arlo "community" for support instead of the non-existent support team.
Hi @HayleyJ
You may also contact support at anytime with any questions. I have attached the link here for you. Arlo Tech Support
Here's what to try if battery is run down to low;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Is there an opportunity to have a link placed at the top of the forum that directs you to the arlo faq search page? Just an idea to improve the newbie user experience.
There's already a search box at the top for this - not a link but I find it works reasonably well. When you enter the search terms, a link at the top left for Support Articles is included to help separate the wheat from the chaff.
This is on the desktop version of the site - dunno about the mobile display but I'd guess it's similar.
I agree, the support is non-existant from what I see when trying to get a simple answer
Not IMPRESSED
So, what's the simple question?
