Camera won’t record motion
  • 1813 Views
Lallen59
I have 3 cameras. 2 work well. The third doesn’t record motion. In settings I can not change the selection from different nothing’ under the “armed” setting
Try removing the camera from Settings, My Devices and resync it.
Lallen59
Hi, @jguerdat I tried that earlier with no luck.  I also switched one of the working cameras OFF for motion in case I could only use two with the base.  I tried the 'not working' camera then and still had the option grayed out.  Firmware is current on base and all cameras.  Battery is fine on all as well.  The camera has live video so its communicating with the base.
Assuming you tried both the app and a browser with the same results, the next step would be to remove all devices from Settings, My Devices and start fresh. That should clear out any weirdness.
  • 1813 Views
