Camera stopped recording/working. Charged battery all the way. Able to see live feed.
My camera stopped recording and I charged the battery all the way, still not recording and motion detector is not working. I can see the live feed, but that is all.
Hey joebeaster,
Try using the motion detection test to see if your camera is detecting motion: How do I use the motion detection test for my Arlo device?
You can also try testing using the default "Armed" mode to see if you're receiving any recordings if you're using other modes.
