This is really surprising to that Arlo pro 2 camera does not detect the car while drive way to get into my garage and this is not just once, this is happening all the time. I do not understand why it does not happen. Car lights are on as well! Any help, I am not happy about that I am even thinking of returning if this issue continue. I can also record manually and send it if helps to fix the problem
What sensitivity setting are you using? Do you have the car coming directly towards the camera?
The sensitivity that I am using for that camera is 100. I attached the screeshot and the video as well.
Video:
SS:
Car is detected and showing clearly in video.
That should pick up but I'm wondering if it's due to the positioning of the camera and the roofline obscuring the PIR motion sensor. Perhaps try moving it elsewhere, even if just temporarily. If this is the position you desperately want, try invert the camera and also invert it in the settings so the video is the right way up. This will put the motion sensor further from the building
Why do you think that roofline obscuring the PIR motion sensor?
Actually the video that I shared is already inverted and same thing in the setting too.
I attached the setting page for that too. I am not sure if it is faulty camera or something else.
OK, either way, I'd position the camera elsewhere, probably lower and more off to the side. PIR sensors don't work well when the IR object moves towards the camera. They work well when the IR signal moves across the field of view breaking "multiple beams"
Unfortunately, I can't see your attached photos til one of the mods or admins here authorises it
Try to re-postion the Motion sensor with an angle. Motion sensor does not work well, when the object is moving toward the camera in a stright line.
steve_t wrote:OK, either way, I'd position the camera elsewhere, probably lower and more off to the side. PIR sensors don't work well when the IR object moves towards the camera. They work well when the IR signal moves across the field of view breaking "multiple beams"
