Camera mount screw stuck in camera! Anyway to remove it?
Screw from indoor/outdoor mount is stuck in my camera! Is there any way to remove it? I have already tried wd40 and pliers, but it just won’t turn!
You've tried what I would have. If you can't "rock" the screw in and out to try to break it free you have to decide whether to force it out, possibly removing the camera's threaded insert, causing you to use a magnetic mount, or just leave it alone and remove the battery for recharging (assuming you can't get the charging cable past the mount's lock nut).
