Boulder co
  • 1 Reply
  • 1254 Views
The4goods
My ARLO pro 2 updated today post battery charge.  I had to reset the base, and reconnect all cameras.   Now I have no night vision… all cameras are dark at night… but before I had auto IR night vision.   Did the IT  guru forget to keep this service in the new programing
Not sure how your camera got updated since the last firmware update was in 2021:
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/m-p/1920885#M791
If you mean your user interface (UI) got updated from the old one that uses Library to view recordings to the new one that uses Feed, you need to check Routines and edit the 3 default modes to add rules as needed. Only Arm Away gets all cameras' rules automatically generated.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
  • 1 Reply
  • 1254 Views
