Bought "New" Pro 2 additional cameras. Can I easily connect it with my Base Station?
Hi,
Bought "new" Arlo pro 2 wire-free addictional camera. Can I easily connect it with my Base Station? They are any chance, that previous owner connected it with his Base and can still using this camera? Can I make any hard reset of this camera?
Hi Maggie7,
You should be able to connect the additional Pro 2 cameras that you purchased to the Base Station.
If you have problems trying to pair your Pro 2 cameras to your Base Station, My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
If you are unable to pair them and it is connected to a previous owner, contact the Support Team so they can help you with this. You will find several options for contacting support in the provided link.
