Not sure if it's the "best" but I just use a 32GB flash drive. It seems to store a surprising amount of data. Maybe I'd go with 64GB if I was doing it now. I think the max limit is 2GB. Or were you asking for recommendations on brands?
2TB
LOL. Yes, typo. 2TB. My bad
toytek63,
Adding to the comments above, take a look here for setup information: How do I set up local storage backups on a USB device using my Arlo Pro base station?
