Cameras have been charging fine until today. While trying to charge its draining what little the battery has left. Thoughts on what's the problem? Tia
@Jld561 wrote:
I only have 2 cameras and 1 charger and it is happening with both cameras
I suspect the charger and/or the cable, since that is more likely to be the problem than both cameras failing in the same way at the same time. So I'd start with a risk-buy of a new charger.
Unfortunately, Arlo doesn't sell the indoor charger for the Pro / Pro 2, but you can get the outdoor charger or a stand-alone charging station:
- https://www.arlo.com/en-us/accessories/VMA4900-100NAS.html
- https://www.arlo.com/en-us/accessories/VMA4400C-100NAS.html
There are some third-party chargers+cables, and stand-alone charging stations out there. I haven't them, so this is not a recommendation - just an observation. Some posters have found them to work well, others have not.
How cold is it?
I only use them in my house so anywhere from 68 to 70
And this is happening with all your cameras? Are you using just one charger?
I have same type of issue!
