  • 6 Replies
  • 1441 Views
Jld561
Cameras have been charging fine until today. While trying to charge its draining what little the battery has left. Thoughts on what's the problem?   Tia
@Jld561 wrote:
I only have 2 cameras  and 1 charger and it is happening with both cameras
I suspect the charger and/or the cable, since that is more likely to be the problem than both cameras failing in the same way at the same time.   So I'd start with a risk-buy of a new charger.
Unfortunately, Arlo doesn't sell the indoor charger for the Pro / Pro 2, but you can get the outdoor charger or a stand-alone charging station:
There are some third-party chargers+cables, and stand-alone charging stations out there.  I haven't them, so this is not a recommendation - just an observation.  Some posters have found them to work well, others have not.
6 REPLIES 6
How cold is it?
Jld561
I only use them in my house so anywhere from 68 to 70
And this is happening with all your cameras?  Are you using just one charger?
Jld561
jeny38mark
I have same type of issue!
  • 6 Replies
  • 1442 Views
