Battery Usage with Location Services ON ALWAYS on Iphone 7. Battery drain on iPhone 7.
  • 1 Reply
  • 797 Views
MuckNoMore
When Location Services is turned On and set to ON ALWAYS using Geoconferecing, there is a tremendous battery drain and Arlo is the number App drain that depletes the iphone 7 battery.
JessicaP
Hey MuckNoMore,
Try to download the newest Arlo iOS app, which is version 2.10 and see if that helps. Otherwise, try to reinstall the Arlo app and reboot your iPhone 7.
  • 1 Reply
  • 798 Views
