  • 5 Replies
  • 1638 Views
Gpw44
Base goes to blinking amber. Tried new cables, new router and all the different resets. Always goes back to blinking amber. Has been this way for a few months which means no cameras. Unit is not very old. I’m
Very let down with this system. Any suggestions otherwise I’m going to swap to a new system that isn’t arlo.
5 REPLIES 5
Is it still under warranty (1 year)?
Gpw44
Unfortunately no, but it’s less than 2 years. Which to me is a huge letdown a system that cost this much wouldn’t last longer.
Are you seeing the base station in the router's attached devices list?
Also, is the base station showing off-line in the app, or is it just the cameras that are off-line?
Gpw44
At first yes. It eventually stopped showing it was connected.
You have to remove the base I. A hard reset. Since then it isn’t found by the app. The cameras I have require the base.
It should show up in your router's attached device list even if it isn't onboarded to your account.
If you have another device that can connect with ethernet (for example, a laptop), you can confirm that the ethernet cable and router LAN port are working properly by connecting up the laptop (turning off its wifi), and then seeing if you can reach the internet.
If the ethernet cable and LAN port are both working, and you don't see the base in your router's attached device list, then the base has almost certainly failed.
If it is in the router's attached device list, then I suggest trying to onboard the base from a PC instead of the app (browsing to my.arlo.com).  Ideally connect the PC with ethernet.
  • 5 Replies
  • 1639 Views
