  • 1 Reply
  • 1113 Views
Nw04jen71
Was connected to MR200 TPLink but router dripping off every 12 hours seems common fault.
Now installed Tenda 4g router and base station connection orange via LAN and will not detect base station via app or myarlo home...called..told me to try laptop. Doesnt work...have gone through all reboots...any help / advice please. Camera was connected and working - now cannotnconnect base station new 4g router which works 100% fine.
The amber Internet LED means the base is connected to the router and has an IP address (you can check that in the router settings). However, something is blocking access to arlo.com which is usually a router security setting. Ports 80, 123 and 443 to arlo.com must be open for the system to work. Do you own the router? If so, log into it and review any settings that may be blocking access. Default settings should work but I have no experience with 4G hotspots/routers.
  • 1 Reply
  • 1114 Views
