Base station keeps going offline
I have done resets before and that is not fixing it. Not sure what has changed but it is frustrating. It seems to happen when my schedule switches from ARMED to my Daytime mode.
I would manually change the arm/disarmed mode for a while to see if it is the schedule or the base.
First you need to determine if it's really offline. Are you getting recordings or can you trigger one? Are the base LEDs green as required? Have you logged out and back in or force closed the app and reopened it? Have you tried a browser to verify?
I just started having the same problem about a month ago. I have had my cameras for 2 years with no problems until recently, my base station keeps going offline and depleting my camera batteries. If I restart the base station it will stay connected for a little bit then it goes back offline again.
What LED status are you seeing in the base when it goes off line? https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
I will have to check that when it happens again,Thanks for the Info
Hi @Rkentjrdo1
