Pro 2 base station siren isn't sounding anymore when I activate it. It says it's activated when I enable it, but no siren.
Any ideas folks?
Thanks.
Hi, thanks for getting back to me.
All sorted now, power cycled it.
Cheers.
Will the siren work again if you power cycle the base station?
When you manually activate the siren does the base station give a short burst of sound like a bird chirp?
Cheers.
