Base Station unable to connect to internet- Arlo Pro
I have had this unit with 2 cameras for over 18 months and no issues until last Sunday 1-24-21 the device said the base station was off line. The LED light showed a steady yellow.
I have had multiple sessions in excess of 4 hours with Arlo Support trying every trick they have thrown at me to no avail..
Things that I have tried with no success
I use Google Wifi mesh for my wifi router.
1. I have plugged the unit directly into the router that is directly connected to the modem- the yellow LED light did not go away
2. I restarted the google wifi router and reconnected the unit- flashing green light appears for the LED, Power light is green, sync light is yellow.- Partial success
3. I did port forwarding and opening the ports (IPV4 and IPV6) using port numbers 443, 123 and 80 for TCP and UDP as recommended by Arlo- no success. The LED light flashes green
4. I have reset factory settings, resync the cameras with the base station- Green power light, flashing green LED light, Yellow sync light.
So here I am at the mercy of the community
As per #4, you have power ( green ) and internet ( it does flash green,normally ), but no cams synced ( cam yellow )
did you attempt to sync a camera ?... done after power and internet. Remember do not hold the sync button. It’s a quick press and then the camera button
