Base Station suddenly disconnected from network which was plugged in to router directly
My base station suddenly disconnect from the network, which I was plug in router directly. Other WiFi or network is fine with normal
Power button reboot ( off then on )
I'm having the same issue. Mine has been off for 2 weeks now, and I've tried all the resets, removing the external drive etc, and it won't reconnect.
Yes, I have reboot already
The network light on again, but when I use my apps, it showed base offline
Hey MyMacRocks and KenNethPcl,
If your Base Station is going offline, read this article to try troubleshooting: My Arlo SmartHub or base station is offline; how can I troubleshoot it?
