Base Station & Wifi Extender connected to a satellite internet/wifi system
Does anyone have any experience with Arlo being connected to a satilite internet/wifi system. (Hughsnet)
Is it reliable enough to stay connected and work properly?
Any discussion or information is appreciated.
I have used both Wifi extenders and later switched to the Netgear Orbi router with 2 satellites. I have a mix of 10 Arlo cameras with three base stations, (one on the router and one each on each satellite). Very reliable.
Brian
I think he means internet sat reception, not like an Orbi....
Biggest issue you will prob have is the data rate you get.... Arlo recommends a min of 1MBS upload.
( tho I believe it should be more like 2MBS )
If you pass the min amount, I would also suggest a Pro or Pro2 model as they have a usb backup if the internet goes out for recording videos ( they record to the cloud and the usb at same time )
