  • 1785 Views
jmurray1214
Today I called customer support 5 times in the UK, the call was taken and put on hold for about 5 minutes then it just cut off everytime, is this the usual level of support from Arlo?
ShayneS
Hi @jmurray1214
Thank you for the feedback, was your issue resolved?
jmurray1214
Hi,
No, I still cannot get an answer to my inquiry, which was will the Solar Panels work with my Arlo Pro 2 cameras, you would not think it would be so difficult to get an answer from a support team.
@jmurray1214 wrote:
No, I still cannot get an answer to my inquiry, which was will the Solar Panels work with my Arlo Pro 2 cameras.
Are these Arlo panels?
What is the part number?
The Arlo panel for the Pro 2 is the VMA4600.
  • 1785 Views
