Availability of Outdoor Security Mount
  • 4 Replies
  • 1153 Views
  • 2 Likes
Golden_Orb
It would seem that the Outdoor Security Mount (VMA1000) for Arlo Pro 2 is no longer available in Australia.  I'm wondering why this is so? Is there a suitable replacement other than the VMA4000?
Can anyone shed any light on this?
jse1982
I got these and they work fine. A tad cheaper construction that Arlo brand but works fine for me.
EEEKit 4-pack Outdoor/Indoor Wall Mount for Arlo Pro 2, Arlo Pro, Arlo, Arlo Go Security Camera, 360 Degree Adjustable Ceiling Mount for Reolink RLC-4 https://www.amazon.com/dp/B0777DR8T5/ref=cm_sw_r_cp_apap_ArgDJGhq96dGi
Any standard 1/4=20 threaded mount will work.... ( camera standard )
Only watch the lock wheel on the mount , some are to large and will get in the way, instead you can use a 1/4-20 nut which will be much smaller in diameter
AncientGeek
Hero
Hero
I just purchased four of the new little “4000” mounting brackets.  They are short with a friction ball and 1/4” - 20 screw.  I haven’t deployed one yet.  I’m taking a few with me on a trip as part of my Arlo “travel security” system.  Netgear MR1100 and a few Pro 2 cameras.
https://www.arlo.com/en-us/products/arlo-pro/outdoor-mount.aspx
But TomMac’s post is right on.
Golden_Orb
Thanks for your help everyone.  I think I might give the 4000s a go.
  • 4 Replies
  • 1154 Views
  • 2 Likes
