Audio Triggered by Wind
1 of 4 cameras keeps triggering because of the wind, all others are fine. All firmware is up to date.
Any ideas?
Any ideas?
Is that camera set to use audio detection in your modes and rules? If so, turn it off. If you need audio detection, try turning the audio sensitivity down a step at a time. You may need to reposition the camera to prevent the wind from hitting the mic the same way.
That's great, refresher of the settings!!
I had moved a door way camera up a tree!
