I have a home and work hub. Need to arm and disarm separately. How is that done in the new app?
@Luke12345 wrote:
is there a way to do through the custom modes?
Yes, if you see custom modes (not everyone does), then you can arm/disarm the hubs independently that way.
But geofencing would require two locations to be set up (unless both hubs are at the same address).
@Luke12345 wrote:
the one subscription was fine before, 5 cameras total.
If you have the 7-day free cloud storage, then there is no subscription issue, since that depends on the number of unsubscribed cameras in the account. But if you have a paid subscription, then you'd need one for each location in the new app.
One way is to create two locations in the account (adding "work"). But if you have a paid subscription, you will need one subscription per location.
the one subscription was fine before, 5 cameras total. is there a way to do through the custom modes? its very confusion to try and set up
