The magnetic attachment makes it too easy to be stolen.
And the sensors don't work through glass which I was not told before buying this! What a waste of money.
You could use the adjustable mount that screws in to the cam instead of magnetic mount.
Who did not tell you t will not work through glass?
That’s good to know that I can purchase an adjustable mount to screw into.
i just noticed the notification never goes off when people walk past the camera from the outside through the window the camera cannot sensor it to me to notify me.
so I googled it and it appears the motion sensor doesn’t work through windows. Not many cameras do at all which I never knew about.
Most of the Arlo cameras use PIR devices to detect motion...they use IR which most glass blocks. Therefore the cameras don’t detect.
The Q cameras ( and baby ) use pixel change to detect, so work thru glass.
I was just typing that tom you beat me to it heh.
I have the Arlo pro 2. Can I change its settings to make it pixel? Or what is (baby).
should I just get a new camera that has pixel?
And thank you for your help here.
I didn’t know people would see my post. I’ve never been in a forum like this before!
He was talking about the Arlo Q cam and Arlo baby cam both on Arlo's product page under indoor cams.
