The past 2 weeks my cameras have been going off line every 30 minutes or so. Last night at 6:30 pm they all went off line and I can not get them back online, 7 cameras. Did they do away with Arlo pro 2 and I can not use them anymore?
I've had this problem for the same long time, its an Arlo thing that they're doing in the updated app to get you to move to the new products. Its a classic move done by a lot of major mfgs, except it wont work on me.
I have new wifi device and now I have two green lights no middle light showing
@XO3 ,
If you have a 4000 base and middle led is blank it suggests that the base doesn’t have a working Ethernet connection to the local router.
check Ethernet cable for damages, make sure you are using a valid port on the router, try another port etc.
If the new router is supplied by the isp check with them that the router is configured to use the port.
If you start getting an Amber condition for the led you have Ethernet working but no internet connection, try rebooting the router.
