  • 6 Replies
  • 3538 Views
Boilermakerny
Hello,
Recently one of my cameras (not wired, no activity zones) began to disable itself randomly. It only happens once a day, but when I check the app this particular camera is disabled.
I have tried recycling the power on the base station with no luck.
When this does happen, I can simply go into the app and re-enable the camera, and it works for about another 24 hours.
Any suggestions are greatly appreciated!
Boilermakerny
I think I'm good to go here. After completely removing the integration, the random disabling of a camera stopped.
To take it a step further I reintegrated Arlo with smart things, this time adding Arlo to an existing room instead of creating a new one. The integration appears to be working.
About 100% sure that this step is necessary, (in other words could you create a new room called Arlo? Not sure) but things appear to be working for me...
6 REPLIES 6
Do you have a schedule enabled?  Or perhaps geofencing?
Boilermakerny
Hello, no schedule or geofencing. I just use the basic armed mode. This is only happening with one of 4 cameras.
By "disabling" do you mean the toggle in the camera settings is turned off?
Boilermakerny
Yes, that's correct.
It's very strange- happens on the same camera, only over night. And seems like it happens between midnight and dawn.
For further background:
I have a Smartthings automation that would kick on some lights when motion was detected on any of my cameras between dusk and dawn.
That feature had been working for at least a year until very recently.
I just deleted all Smartthings automations to see if that was causing a problem.
There is a related thread on the Smartthings forum regarding a recent bug in the Arlo / SmartThings integration:
https://community.smartthings.com/t/new-smartthings-schema-integration-for-arlo/210605/429
Boilermakerny
UPDATE: I removed the Arlo integration within the Smartthings app, and the camera did not disable itself last night.
I previously tried removing any automations that interacted with Arlo, but that was not successful. Apparently the full removal of integration between the two seem to help.
I will update the thread if I can go a few days without the camera getting disabled.
Still not sure why things got jacked up in the integration between Arlo and Smart things.
Boilermakerny
  • 6 Replies
  • 3539 Views
