Arlo pro 2 camera power question.
Can the new Arlo Pro 2 camera be run on indoor power with the battery installed, or is it best to remove the battery and run it only on indoor power with the approved AC adapter so you don't have to worry about recharges?
The Arlo Pro and Arlo Pro 2 Cameras are both designed to work great off the included rechargeable battery. There is no need to remove the battery when indoors.
Please click
KUDOS or REPLY If you found this helpful.
I understand your answer, however because there is so much motion in the monitored area, the battery only lasts five or six days and requires recharging. I live in a diiferent state and cannot get there to keep changing batteries. Hence the question. Can the Arlo Pro and Arlo Pro 2 cameras be run on constant AC power so I don't have to worry about the batteries running down?
