I have 5 cameras that have worked fine for years. 1 of them recently stopped detecting motion. When I try to do the motion test it tells me there is an internal error.
Have you tried to remove then re-insert the battery in the camera? You might also want to power cycle your base station.
Brian
Yes, I have tried both
